  3. Right Angle Route/Slot in Padstack?
  • Replies 9
  • Subscribers 167
  • Views 8393
melview1
melview1 over 5 years ago
I'm looking for advice on how to create an odd shaped padstack for some mounting pads on a USB connector (see top 2 mounting pads in picture).  It's a plated slot/route that has a right angle and the pad is the same shape.  The pad shouldn't be that hard to do with the "shape symbol" option for the pad layers, but the drill has me at a loss as to the best way to do it.
Thanks.
  • steve
    steve over 5 years ago +2
    You could always draw the outline of the slot using Board Geometry / Cutout then on the inside draw the actual route path using Board Geometry / NCRoute_Path. Make sure this line is drawn at the actual…
  • excellon1
    excellon1 over 5 years ago +1
    There is no provision to do Path Operations for routing boards in the Cadence tool so you will have to go another route instead. Create the pad using a shape on all layers you need. Inside the pad you…
  • DE202408202727
    DE202408202727 over 5 years ago +1
    I have found that the best way to do this is with two pins:
  • DavidJHutchins
    DavidJHutchins over 5 years ago
    I think eDave's suggestion is the way I would do this, since you can control the plating of the slot, the NCROUTE_PATH is non-plated
  • excellon1
    excellon1 over 5 years ago in reply to DavidJHutchins
    David can you offer some insight on that. Not too sure what you mean with respect to controlling the plating of the slot.
    Thanks.
  • DavidJHutchins
    I the USB connectors I have built like this one, these slots are for connecting the metal shroud to GND, so they need to be plated
    If you enable 'Separate files for plated/non-plated routing' in the NC Route form you will get 2 output files: <design_name>_<1-n>_plated.rou and <design_name>_<1-n>.rou
  • jc teyssier
    jc teyssier over 3 years ago in reply to DavidJHutchins
    I find a layer is dedicated to plated slos: BOARD GEOMETRY/NCROUTE_PLATED
    A line present on this sublclass will be present in outpout ncroute file.
    BOARD GEOMETRY/NCROUTE_PATH  is only for non plated slots.
    Works fine on 17.2
