  3. Save issue when write DFA info in 17.2
  • Subscribers 159
  • Views 12097
Jason Hsu
Jason Hsu over 4 years ago
Hi everybody,
  I always can get great help from here. Thanks all of youGrinning. Now, I have a question when I do allegro2valor information convert. This below is my code for writing DFA, it can run on 16.6. The Design DFA Table will show and save, close. But the Table will stop when I run it on 17.2. I guess it is "save" issue. Just like the red line in the code. If the script have some update in 17.2 environment? Please help me, thanks in advance.
  BTW, I can't debug my code in 17.4 skill window. The telskill window is blank, I can't input anything on it. If all of people like me? Anybody know how to solve it? The Form table also have some issue, the width of field is difficult to define.
    brd_name = axlCurrentDesign()
    if(axlVersion('isWindows)
    then
           dfa_script_file = strcat(getShellEnvVar("TEMP") "/dfa.scr")
     else
          dfa_script_file = "/tmp/dfa.scr")
     dfa_script = axlDMOpenFile( "ALLEGRO_OUT" dfa_script_file "w" )
     sprintf( dfa_out    "dfa_%s.txt"   brd_name)
     fprintf( dfa_script "dfa_spreadsheet\n" )
     fprintf( dfa_script "setwindow dfa.dialog\n" )
     fprintf( dfa_script "dfa read_from_design\n" )
     fprintf( dfa_script "dfa save \"%s\"\n" dfa_out )
     fprintf( dfa_script "dfa cancel\n" )
     axlDMClose( dfa_script )
     axlShell(strcat("replay " dfa_script_file))
     deleteFile(dfa_script_file)
Best Regards,
Jason
  • DavidJHutchins
    DavidJHutchins over 4 years ago
    The command syntax was changed in 17.x, below is an example:
    dfa_spreadsheet
    QtSignal DFAMainWindow m_actionSave_As triggered
    QtFillin cds_routed_172.dfa
    QtSignal m_sprdSheetGrp m_spcValLineEdit editingFinished 25:25:25:25
    QtSignal DFAMainDialog m_okBtn clicked
    QtSignal MainCanvas DFAMainDialog closed
  • Jason Hsu
    Jason Hsu over 4 years ago in reply to DavidJHutchins
    David,
      Thank you very much for your reply. But I still can’t get the meaning. Could you please tell me where I can find these example? I need the detail to correct my code. Thank you in advance.
    Best Regards,
    Jason
  • DavidJHutchins
    With 17.x the applications were updated to use Qt, which is a cross-platform application development framework.
    As such, some of the Allegro user-interface commands such as "setwindow dfa.dialog" were replaced with "QtSignal DFAMainWindow",
    so some existing scripts need to be rebuilt using the 17.x syntax...
    An easy way to do this is to open Allegro & run the command & then exit Allegro, then use j2script to convert the allegro.jrl into an example script...
  • Jason Hsu
    Hi David,
      I have to ask your help again, please tell me how to deal with this issue.
      When I define dfa_out as -- sprintf( dfa_out    "dfa_%s.txt"   brd_name).
      In 16.6, it is fine -- fprintf( dfa_script "dfa save \"%s\"\n" dfa_out ). The file dfa_xx-xxxx.txt will create, my code will continue.
      In 17.x, fprintf( dfa_script "QtSignal DFAMainWindow m_actionSave_As triggered\n" )
                   fprintf( dfa_script "QtFillin \"%s\"\n" dfa_out )
      The file dfa_xx-xxxx.txt.dfa is created. The system show: Error: File dfa_xx-xxxx.txt not found. I only can find dfa_xx-xxxx.txt.dfa file in folder. How should I treat it? Please help me, thank a lot.
    Jason
  • DavidJHutchins
    the following script works for me in 17.4:
    dfa_spreadsheet
    QtFillin "BeagleBone_Black_RevB6_nologo.dfa"
    QtSignal m_sprdSheetGrp m_spcValLineEdit editingFinished "25:25:25:25"
    QtSignal DFAMainDialog m_cancelBtn clicked
    generaledit
