  3. Plated Mounting Hole covered by SolderMask
  • Replies 10
  • Views 17815
jatins
jatins over 4 years ago
Hi
I have used 3 plated Mounting Holes in my PCB which are connected to Ground.
In 3d Canvas: Out of these 3 holes, one hole is getting covered by SolderMask on Top and Bottom Layer while the others are shown OK.
Same footprint is used on all 3 holes and i ran Check>Design  Status> Update Shape to Smooth to see if it helps but it doesn't.
Same result when i export  this Step File Out of 3D Canvas.
Using latest hotfix 17.4 S023
  • steve
    steve over 4 years ago in reply to jatins
    Not prepared to put an email on a public site so you can upload your board onto the forum. If you don't want to put it here make a simple example (just the board profile and mounting holes) and upload that.
  • jatins
    jatins over 4 years ago in reply to steve
    OK
  • steve
    You have uploaded a step model, I need to see a board file so I can look at this in Allegro....
  • jatins
    OK. I made a gerber file out of board. Believe this shows all the info you need.
    https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/27/5857.SM_5F00_Pin_5F00_TopBottom_5F00_Outline.zip
  • steve
    A Gerber file won't show the the padstack etc. Make a new board file, copy the profile and fixing holes ONLY into this board file (view it in 3d and make sure you see the same issue) then save it and upload that so we can look at the board file.
