  3. Can't use hotkeys after I press the E key
  • State Verified Answer
  • Replies 11
  • Views 9218
jeboothy
jeboothy over 4 years ago
I took the trouble of setting up some useful hotkeys (move, rotate, mirror, done, etc...). The program is almost unusable to me without them. They start off working perfectly, but after 1-10 minutes, all hotkeys stop working until I restart the program. It only takes 20 seconds, but it is very very annoying. I've noticed that pressing the E key at any time breaks all of the hotkeys, I'm not sure if any other key does. It's pretty easy to accidentally press E while I'm working. Maybe I am stuck in some sort of tool I can't get out of, but the hotkeys won't work until I restart. I have a hotkey bound to 'done' and 'cancel', and neither helps it recover. Any help would be appreciated.
Best
  • mahimag
    mahimag over 4 years ago +1 verified
    This might happen when we have mistakenly entered an incorrect command on the command prompt, say blank space or may be a full stop “.”, which are not easily recognizable. Instead of restarting, either…
  • RFinley
    0 RFinley over 4 years ago in reply to jeboothy
    But, hotkeys usually only work if a mistyped string, valid alias or command has not been started.
