  3. How to display Rats nest for GND as cross and not as li...
  • State Verified Answer
  • Subscribers 160
  • Views 14416
How to display Rats nest for GND as cross and not as lines
JacobPrevas
JacobPrevas over 3 years ago
Hello!
I have a hopefully quite simple question. How do I toggle between showing Rats nest as lines and crosses. Especially GND net is important for me to show as a cross.
I cannot seem to find the option to toggle this feature.
I am using Orcad PCB Designer Professional 17.4.
First image is what I mean with showing Rats nest as lines and second is as cross.
  • steve
    +1 steve over 3 years ago
    This is controlled by the Voltage property. Open Constraint Manager (Setup - Constraints, the the Properties - Net - General Properties and add a voltage for the GND net (0) then the display will be shown as "crosses"
  • DS1995
    0 DS1995 over 3 years ago
    Adding to Steve's reply, there is an alternate method to achieve this:-
    Edit properties > Select "Nets" in find filter > Select "More" in Find by name in this window > Find the Voltage Net where you want to change the ratsnest display > In the edit property dialogue box Select "RATSNEST_SCHEDULE" and in the value select "POWER_AND_GROUND"
    Good Luck Thumbsup
  • JacobPrevas
    0 JacobPrevas over 3 years ago in reply to steve
    Thank you for a quick answer!
    This worked, is there anything else that changes when i add a voltage to a net?
