  3. No License found with LAN. License found with WLAN.
  • State Verified Answer
  • Replies 9
  • Answers 1
  • Views 24197
McVegas
McVegas over 4 years ago
i use Cadence Allegro 17.4 and everything is up to date. License manager version is 11.14.1.0.
When i connect with VPN and WLAN frome home, the license will be found.
When i connect with VPN and LAN from home, no license will be found.
If i connect with LAN at company, license will be found. WLAN too.
I work with a local dongle on my notebook.
Follow information is shown at home, when it doesnt work.
"Retrieval ao 'Allegro_performance' license failed: 'ERROR (LMF-13015): Licnese call failed for feature PCB_design_studi. The license server search path is defined as <none>. The FLEXnet error message is as follow, FLEXnet ERROR (-15,234, 0): Cannnot connect to license server system.
Run 'lic_error LMF-13015' for more information'. Report the licenses in use log via the menu item File->Viewlog: License_use.log.
Notebook System is Windows 10.
VPN is CheckPoint.
Any idea, where the problem could be?
Thanks.
  • DavidJHutchins
    DavidJHutchins over 4 years ago +1 verified
    OK, so you are only looking at your local USB dongle for licenses, nothing from the LAN or WLAN Is your local license server running? Please check by running lmutil lmstat, an example from my laptop…
  • McVegas
    McVegas over 4 years ago in reply to DavidJHutchins +1 verified
    Deleted
  • DavidJHutchins
    0 DavidJHutchins over 4 years ago in reply to McVegas
    No, your local license server is NOT running, the difference between my laptop & yours:
    [Detecting lmgrd processes...]
    License server status: 5280@asus-laptop
    License file(s) on asus-laptop: D:\Cadence\LicenseManager\license.dat:
    asus-laptop: license server UP (MASTER) v11.14.1
    Vendor daemon status (on asus-laptop):
    cdslmd: UP v11.14.1
    yours:
    Error getting status: Cannot connect to license server system. (-15,10032)
    You need to attempt to restart your Cadence Licence Server ( from the services application )
  • McVegas
    0 McVegas over 4 years ago in reply to DavidJHutchins
    Yes. The dongle is local on my notebook. I only need the VPN to have access to company network, library etc.
    The local license server is running.
    With WLAN:
    C:\Cadence\LicenseManager>lmutil lmstat -c 5280@XXXXXXXXXXX -f
    lmutil - Copyright (c) 1989-2016 Flexera Software LLC. All Rights Reserved.
    Flexible License Manager status on Mon 2/21/2022 20:50
    License server status: 5280@XXXXXXXXXXX
    License file(s) on XXXXXXXXXXX: C:\Cadence\LicenseManager\license.dat:
    XXXXXXXXXXX: license server UP (MASTER) v11.14.1
    Vendor daemon status (on XXXXXXXXXXX):
    cdslmd: UP v11.14.1
    Feature usage info:
    Users of Allegro_performance: (Total of 1 license issued; Total of 0 licenses in use)
    Users of Allegro_studio: (Total of 1 license issued; Total of 0 licenses in use)
    Users of COSLITE_ACCESS: (Total of 1 license issued; Total of 0 licenses in use)
    Users of PCB_design_studio: (Total of 1 license issued; Total of 0 licenses in use)
    Users of SPECCTRA_HP: (Total of 1 license issued; Total of 0 licenses in use)
    Users of SPECCTRA_PCB: (Total of 1 license issued; Total of 0 licenses in use)
    With LAN:
    Flexible License Manager status on Mon 2/21/2022 20:59
  • DavidJHutchins
    With the LAN can you ping the license server XXXXXXXXX?
    I would also change the CDS_LIC_FILE setting to point first to your local dongle & then the network licenses by separating the values with a ";", example below:
    CDS_LIC_FILE="5280@laptop;5280@XXXXXXXXXXX"
  • McVegas
    Hi David.
    First of all, thank you for your help.
    There is no license server at my company. We work with usb dongle on each notebook.
    The problem was, that my telephone system at home and VPN (company) create their own IP adress.
    The licensce manager found two different IP adress.
    Solution: i use 5280@localhost at my CDS-LIC_FILE now.
    No further problems at WLAN and LAN. A little bit stange, my colleague does not have this problem with the same system.
