  3. outline vs design outline
  • State Suggested Answer
  • Replies 10
  • Answers 3
  • Subscribers 167
  • Views 19459
myil17
myil17 over 4 years ago
Hi All,
I am new to pcb design and cadence. I would like to ask what the difference is between outline and design outline?
Where to use design outline and where to use outline?
Regards
  • DE202408202727
    DE202408202727 over 4 years ago +1
    The BOARD GEOMETRY/OUTLINE layer was obsoleted in 17.2. It's there for legacy reasons but you can ignore it.
  • masamasa
    masamasa over 3 years ago in reply to JITHINDEV +1
    providing to who? the answer would be dependent on whom u are providing the design to.
  • masamasa
    masamasa over 3 years ago in reply to JITHINDEV +1 suggested
    if u r using 22.1, u do not need outline but design outline only.
  • masamasa
    0 masamasa over 3 years ago in reply to JITHINDEV
    u did not give me an answer to my question as to whom u r providing the design to.
    but i reply to ur comment.
    if the receiver of ur desgin still uses 16.x, u need ouline.
    otherwise u do not need outline but only design outline.
  • JITHINDEV
    0 JITHINDEV over 3 years ago in reply to masamasa
    we will not provide our design file directly to any one. only share the Gerber files to Fab.
    and I am using 22.1 editor
  • masamasa
  • JITHINDEV
    I got few info about Board outline and and Design outline mented below;
    1. Board Outline: This typically refers to the physical or mechanical outline of a printed circuit board (PCB) or a similar electronic component. It defines the shape and dimensions of the board itself, including the location and size of mounting holes, connectors, and other physical features. The board outline is crucial for ensuring that the PCB fits into its intended enclosure and interfaces correctly with other components.
    2. Design Outline: This term might be used more broadly and could refer to the conceptual or schematic outline of a design project. It may include specifications, requirements, and high-level design considerations. In the context of PCB design, the design outline might encompass the overall functionality and purpose of the circuit, the arrangement of components, and the interconnections between them.
    The level of detail and the specific content within these outlines can vary widely depending on the project and its requirements. In many cases, both the board outline and the design outline should align and provide essential information for successful project execution. However, they serve different purposes: the board outline deals with the physical aspects, while the design outline focuses on the conceptual and functional aspects
    Correct me if i am wrong.
    Jithindev MK
  • steve
    0 steve over 3 years ago in reply to JITHINDEV
    This video should help Tutorial OrCAD Allegro Design Outline Cutouts - YouTube
