  3. Allegro - Tip of the Week: Display numerical sequence of...
  • Subscribers 158
  • Views 1708
Allegro - Tip of the Week: Display numerical sequence of layers in Visibility pane
PCBTech
PCBTech over 3 years ago
If you are having difficulty mapping via labels to actual layers or simply wish to see a numerical order of the layers in stackup, consider enabling the “Show layer numbers” option in the Visibility Pane tab of the Color Dialog form. When enabled, the sequential layer numbers appear in the first column of the Visibility pane.
Team PCBTech
Cadence Design Systems
