  3. PCB Editor DRC errors with non-plated mechanical holes that...
  • Subscribers 171
  • Views 15067
PCB Editor DRC errors with non-plated mechanical holes that are just holes
Jessicak
Jessicak over 4 years ago
Hi All,
I have connector that requires mounting holes. These are just holes, no copper. I have defined the padstack as non-plated. and mechanical. but it seems not to undrstand that there can be no copper.
I have added a pad as padstack requires it, I have tried smaller than the drill size, equal drill size but I get the following DRC errors when I use the symbol.
Annular Ring: Pin Pad Missing mask. But I do not need or want a mask there is no copper to mask as it is drilled away
Annular Ring: Pin hole to Pad Again no annulus ring as there is no copper.
It is as if Cadence does not understand that sometimes all you want is a hole.
I guess there is something hidden somewhere that I can set that tells cadence that it is just a hole
Thanks for any help
Jessica
  • CS202410277725
    0 CS202410277725 over 2 years ago
    When encountering DRC (Design Rule Check) errors in a PCB editor related to non-plated mechanical holes, the software often interprets these holes as potential issues. Non-plated holes are typically meant for mounting or alignment and shouldn’t interfere with electrical pathways. https://clicksud.com.co/ .I am also impressed by this website.
