  3. How to prevent flooding under components?
  • State Suggested Answer
  • Answers 2
  • Subscribers 168
  • Views 14272
Manfred1
Manfred1 over 4 years ago
Hi!
I have relatively large SMD ceramic capacitors. Their symbol does not contain a keepout area, which is O.K. I want to prevent the system from filling the whole area underneath the capacitors (except the positive pin + surrounding) with GND plane. I simply have to draw a rectangular shape under the capacitor. How is that shape called? Void, cavity? What is the correct layer: Etch, Anti Etch, something else?
Kind regards, Manfred
  • Manfred1
    Manfred1 over 4 years ago in reply to RFinley +1 suggested
    It looks like excellon1 provides the answer to my question in this thread: Create an opening in an existing copper pour I must note, that this is very counterintuitive: Voids/Cavities exists in the Design…
  • excellon1
    excellon1 over 4 years ago in reply to Manfred1 +1 suggested
    Manfred there is a bit more to using the Route Keepout with symbols aka footprints. In allegro as you are aware it is possible to add a shape to the route keepout class but that does not mean you can…
  • Annette Fleming
    0 Annette Fleming over 4 years ago in reply to excellon1
    excellon1 said:
    Maybe try the following on your symbol that you don't want to have the copper pour flooding under.
    1 Add a shape Typically a rectangle on the "Route Keep out Top layer of your symbol" Extend this shape so it clears the symbol and pins by a keepout distance you want.
    2 In the find filter select shape if it is not already selected and hover over the edge of the shape until you see it highlighting. Right click and select properties.
    Add the following properties to that shape.
    Vias allowed.
    it really worked for me, thank you so much
     free solitaire
