  3. Total Etch Length Matching
  • State Verified Answer
  • Subscribers 166
  • Views 15870
SLSCORP
SLSCORP over 4 years ago
How to set up constraint for this kind of etch length matching. Currently, it is very difficult process as we calculate it individually and sum it to match the total length. If a board is having multiple this kind of nets and more number of components in series then the length matching consumes too much time. What is the best method to do this kind of length matching?
  • oldmouldy
    oldmouldy over 4 years ago +2 verified
    This is what PCB Editor calls an XNet, eXtended Net. In any PCB Editor product, you can create XNets by assigning Signal Models to components with the Discrete Class property value through the Setup>More…
  • JuanCR
    JuanCR over 4 years ago in reply to SLSCORP +1
    Open your Constraint Manager (Setup > Constraints > Constraint Manager ...). Then go to Tools > Options and make sure that you have this option set up like this: If you have it setup like this, you…
  • steve
    0 steve over 4 years ago in reply to SLSCORP
    There is a solution on the Cadence Online Support site that may help:- How to create Xnets through ICs (cadence.com)
