  3. Pads are rotated 90° compared to .dra file
  • Replies 7
  • Subscribers 167
  • Views 14601
SOT23
SOT23 over 4 years ago
Hello !
I am facing a very strange problem : some footprints have their pads rotated 90° compared to what I did in the dra file :
This is supposed to be a 1210 chip capacitor
I have had this problem in two different occasions :
- While quickplacing components on a new design, the pads where rotated 90°.
- While refreshing pads on a design that was already routed. I had to modify a padstack and refreshed all the pads. Big mistake... Now I have all my 1210 capacitor pads rotated.
Why is this happening ? This is very weird and very unwanted... Does anyone have a solution ?
I am using OrCAD Pro, 17.4 S029
  • SOT23
    0 SOT23 over 4 years ago in reply to Schulz Jordan
    Sorry for the late reply, got caught up by work and kinda forgot about this post !
    Do you mean that if I want, let's say, a 1mmx2mm pad, I can't use a 2mmx1mm pad ?
  • redwire
    0 redwire over 4 years ago in reply to SOT23
    What is probably happening is that the DRA has a specific pad rotation on it.  That pad rotation has obviously changed its definition through its lifetime.  When Allegro imports the symbol, it also imports the pad separately with the applied rotation on it.
    That is when you will see this issue.  You need to go back to the DRA file and re-import the pads, and assuming the pads live in one place, you should see the issue in the symbol.
