  3. Altium .PcbDoc translation to OrCAD .brd "Divide by Zero...
  • Views 5936
Altium .PcbDoc translation to OrCAD .brd "Divide by Zero Error"
MrStrange
MrStrange over 4 years ago
Hello All,
    We are kicking Altium to the curb after much abuse at the hands of their software developers over the years.
    I'm trying to translate the Altium ASCII PcbDoc file and the process repeatedly terminates in the Command Window: as shown below without actually producing the translated .brd file.
Performing a partial design check before saving.
Writing design to disk.
'unnamed.brd' saved to disk.
'03_CentralGateway_Logic.brd' saved to disk.
*Error* quotient: Attempted to divide by zero
The final lines of the Altium translator process is shown below.
4.3.1 INFO - [575] Start Component "TP1214" with Footprint "TP200" SCH_FOOTPRINT: nil - ("TP200" "TP200_3" "3" 1 "TP1214" 42007.52 20643.94 "BOTTOM" nil 90.0 "TP1214" "TP200")
4.3.2 INFO - For Component "TP1214" Footprint "TP200" already exist.
4.3.11 INFO - Footprint "TP200" ID: dbid:000001C9249BF6B0 t created
4.3.0 INFO - END of [ 575] Successful footprints creation of [ 575] Total - End Time: ["Oct 25 08:55:46 2022"]
X.1.02 INFO - Board File: "./translator.run/02_CentralGateway_Dump.brd" saved | DBCheck: Errors = 44; Warnings = 1
4.0.0 INFO - Start to Create Device File.. - Start Time: ["Oct 25 08:55:47 2022"]
4.0.1 INFO - Footprint Mode set to Generic.
4.0.0 INFO - End of [ 1] Successful Device File Creation of [ 1] Total - End Time: ["Oct 25 08:55:47 2022"]
4.7.0 INFO - Start to Create [575] Component AND Net Logic - Start Time: "Oct 25 08:55:47 2022"
4.7.1 INFO - Footprint Mode set to Generic.
4.7.2 INFO - Part and net logic sourced from schematic.
4.7.0 INFO - END of [ 1] Successful Component and Net Logic Creation of [ 1] Total - END Time: ["Oct 25 08:55:47 2022"]
X.1.03 INFO - Board File: "./translator.run/03_CentralGateway_Logic.brd" saved | DBCheck: Errors = 0; Warnings = 1
3.0.0 INFO - Start for Board Setup...
3.0.1 INFO - Start to clear all existing data first
3.2.0 INFO - Start to add Board Records
Please help me out with some suggestions to get me past this if you can.
Thank you,
MrStrange
  • MicheleB
    0 MicheleB over 3 years ago in reply to MrStrange
    Hello all,
    I'am using  ORCAD PCB Design 17.4-2019 S033 [10/8/2022] Windows SPB 64-bit Edition , and I'm trying to import PCB from Altium 23.0.1. I have the same problem : import failure with *Error* quotient: Attempted to divide by zero messagges.
    There is somethings that I can do in Altium or in the import ORCAD procedure to fix this problem?
