  3. Cutout and creepage distance
  • Subscribers 162
  • Views 8799
R Villefrance
R Villefrance over 3 years ago
Hi
I've inserted a cutout between two through hole slots to enable a tighter fit on the PCB.
Is it possible to setup the constrains, so it understands that there's a hole in the board and the creepage distance between the two pins (and also routing) therefore is large enough?
Right now the spacing between L1 and L2 is set to 6.3mm.
  • avant
    0 avant over 3 years ago
    Create a spacing region to override the default constraint. I've done the same thing for creepage.
  • DBremen
    0 DBremen over 3 years ago
    I know that the German Channel partner has a solution for accurate Creepage and air gaps
