  3. padstack selection
  • State Verified Answer
  • Subscribers 161
  • Views 6882
padstack selection
masamasa
masamasa over 2 years ago
hello
i have two padstacks where small ones are placed over a large one as shown below.
how can i select a small padstack without selecting a large padstack?
whenever i select a padstack, it only picks up a large padstack.
is there a way to select a small padstack and a large padstack and de-select the large one?
  • steve
    +1 steve over 2 years ago
    There are a couple of things to try, the first one is to use the TAB key to cycle through the objects, if that doesn't help try a right click - Reject and you should then see a list of objects you can choose.
  • masamasa
    0 masamasa over 2 years ago in reply to steve
    hello steve
    the tab key works whereas there is no reject command on my rmb menu.
    thanks again
