  3. Xprobe Toggle
  • Subscribers 166
  • Views 12410
Xprobe Toggle
PRKumar
PRKumar over 3 years ago
Hello Everyone,
I'm using Allegro 17.4 HF(S032). I would like to assign a function key for "enable crossprobing". The command is "xprobe toggle". So that, I can use a single function key to toggle the function whenever I needed.
But for some reason the command is not working in the allegro 17.4. Could anyone help to check it why it's not working. TIA.
  • VVRD
    VVRD over 3 years ago +1
    Hi PRKumar, It is working. I just checked. I was able to set F1 for crossprobing. Type alias F1 xprobe toggle in command window. Thank you.
  • VVRD
    VVRD over 3 years ago in reply to PRKumar +1
    Hi PRKumar, I did that in 17.4 S032 hotfix.
  • Schulz Jordan
    0 Schulz Jordan over 3 years ago in reply to PaxtonLeiny
    You also need to enable the inter tool communication in capture. At the worst case rename cdssetup & try this should solve the problem
