  3. Orcad 22.1 Script to Change grid not working
  • Subscribers 159
  • Views 6743
Nilanjan Talukder
Nilanjan Talukder over 2 years ago
Hi All,
I have been using this script to toggle grid in 17.4 when I try to use the same script in 22.1 I get the output on the command line
This is the command
funckey g 'settoggle gridvalue 0.1 0.25 0.5 1 2 5 10; replay gridset $gridvalue;echo grid = $gridvalue'
I get the following output in command line but the grid stays to the default value.
N
  • SandeepVarrier
    0 SandeepVarrier over 2 years ago
    Share the gridset.scr  or copy the lines here
