  3. is any option to convert all old library 15.x folder in...
  • State Suggested Answer
  • Answers 1
  • Subscribers 160
  • Views 7055
is any option to convert all old library 15.x folder in single comments ?
kabalee
kabalee over 2 years ago
Hi Team,
I am struggling to convert the xx.dra file (old version of 15.x)
I have more xx.dra file in 15.x version (around 50 footprint) . Each time i need to choose DB Doctor for one footprint and convert it. is any option to convert old library folder in one comment or single shot.
  • DBTCH
    0 DBTCH over 2 years ago
    Hi Kabalee  ,
    you can use wildcards as your imput file to convert all DRA at one time . You can can do it with Dbdoctor UI or in commandline .
    Regards ,
  • kabalee
    0 kabalee over 2 years ago in reply to DBTCH
    Hi DBTCH,
    is wildcards is software ? i could no find any dB doctor UI . i have only this option to convert . Kindly help
  • DBTCH
    0 DBTCH over 2 years ago in reply to kabalee
    Just filled your path to lib with *.* at the end like "D:\temp\lib\*.*"
  • heathcotegeo
    0 heathcotegeo over 2 years ago
    If you want to convert all DRA at once, you can use wildcards as your input file. You have the option of using the Dbdoctor UI or doing it via the command line.
