  3. Application mode-shape edit -not working
  • State Suggested Answer
  • Replies 8
  • Answers 1
  • Subscribers 160
  • Views 3613
Lock2002
Lock2002 over 2 years ago
I am unable to edit shape corners. I typically convert all 90deg corners to a radius by manually setting the trim size. It isn't a file setting as I've confirmed it's not working on any file I open. It's still working for my coworkers and we have the same revision software so I know it must be an embedded setting that's causing the problem. I've verified the options settings and everything else that's obvious. I've also ran db doctor. Any thoughts?
  • steve
    0 steve over 2 years ago
    Find Pane settings????
  • Lock2002
    0 Lock2002 over 2 years ago in reply to steve
    All objects selected. I've been using this tool for two decades...
  • steve
    0 steve over 2 years ago in reply to Lock2002
    Sorry for stating the obvious but sometimes that is what it isInnocent :Does the command line say anything? Can you try reducing the trim size
  • Lock2002
    command lines doesn't say anything. I normally adjust plane corners using "set trim size by cursor". I've tried a fixed number (small) as well.
  • edhickey
    0 edhickey over 2 years ago
    open color dialog - layers - stackup - is boundary class enabled?
