  3. VIA to VIA spacing isn't true in allegro cadence.
  • State Verified Answer
  • Subscribers 159
  • Views 2753
mrcuongcon
mrcuongcon over 2 years ago
I set the VIA to VIA spacing in allegro cadence (v17.2) to 1mil, but allegro not show error in some case.
(1)(2) Via pad to VIA pad ovelap ( but VIA drill not overlap) -> Cadence show error -> OK
(3) Via pad to VIA pad overlap, and Drill via to Drill via overlap too ( but not all part of Via Drill) -> cadence not show error, not OK
(4) Overlapping two VIA ( all part of VIA ) -> cadence show error -> OK.
Pls see detailed in attached picture
https://drive.google.com/file/d/1tq6xxt0YuE3uD2WyMIXe2cW23tzmv3L4/view?usp=drive_link
So, in case (3), is there an issues of allegro cadence?
  • Schulz Jordan
    0 Schulz Jordan over 2 years ago
    Check with latest hotfix update 17.2 S083
  • Schulz Jordan
    0 Schulz Jordan over 2 years ago in reply to Schulz Jordan
    Also, make sure you have enable the DRC in analysis mode & checked on-line DRC checkbox. I tried the same query & was able to get DRC error
  • mcatramb91
    +1 mcatramb91 over 2 years ago
    When two same net Vias overlap each other they will generated a DRC until the center of one via crosses over the pad of the other via.  At that point the Vias will be considered directly connected.so a DRC Error is not seen.  If you want to see a DRC in this situation you will need to change Pad-Pad Connect under Physical to not allow direct connections, NOT_ALLOWED. (Default is set to ALL ALLOWED.)  See images below.
    Hope this helps,
    Mike Catrambone
    • Vote Up +2 Vote Down
