  3. How exactly does this physical constraint "Allow" function...
  • State Verified Answer
  • Answers 1
  • Subscribers 160
  • Views 4497
How exactly does this physical constraint "Allow" function work?
Ram1234
Ram1234 over 2 years ago
Hi Team,
Good Day!...,
I couldn't figure out "how this Allow works in physical constraint" because there are multiple drop-down menus, each with a different function.
what is mean by Ts and it stands for ?
To better understand the concept, kindly explain in depth with a few examples.
Thanks in advance.....
  • steve
    0 steve over 2 years ago
    Pad-Pad Connect = Checks whether a pin/via whose connect point lies within the extents of another pin/via forms a direct connection without the presence of an intermediate cline. You can choose from the available values:
    ALL_ALLOWED - Specifies that direct connections can form anywhere.
    VIAS_PINS_ONLY - Specifies that only pin-via and pin microvia direct connections can be formed.
    VIAS_VIAS_ONLY - Specifies that only via-via and via microvia direct connections can be formed.
    MICROVIAS_MICROVIAS_ONLY - Specifies that only microvia-microvia direct connections can be formed.
    MICROVIAS_MICROVIAS_COINCIDENT_ONLY - Specifies that microvia-microvia direct connections can be formed, only if the microvias are co-incident.
    NOT_ALLOWED - Prohibits direct connections everywhere.
    Clear - Clears the previous settings.
    Note: Use for conditions where one or both of the pads, vias, or microvias that should be overlapping or coincident is a surface mount device pad. For example, this allows symbol surface mount device pads to embed associated fan-outs without the need to draw a connect line.
    The T is whether a T connection is allowed / where it is allowed. A T is a connection of clines that form the letter T (right angled connection). Some users don't allow these others do.
  • Ram1234
    0 Ram1234 over 2 years ago in reply to steve
    Hi steve
    Thanks for your response,
    Can you please explan in detail.....
  • aniju
    +1 aniju over 2 years ago
    its a Pad-to-Pad overlap checks, please see below Pad-Pad conditions.
    PAD-PAD:
    Constriant Set to 'Not-Allowed', if any via are overlaping with pins, it will flag the DRC.
    Constriant Set to 'VIAS_PINS_ONLY', it means pins and vias are accepatble and won't flag the DRC.
    Constriant Set to 'VIAS_VIAS_ONLY', It means Via-Via overlap is only acceptable, if via overlaps with pads will flag the DRC, similarly for microvias and pins.
    TS: Ts is a T junctions on subclass of cline segments, here are conditions.
    Set Ts as Not_Allowed. it means T- junctions are not allowed anywhere in the net but T-junction is present here and flagging the DRC.
    Set Ts as 'PINS_VIAS_ONLY'. it means T-junctions are accepted at Pins or vias. here is the DRC which is outside of PINS and VIAS.
    Set Ts as 'NOT_ALLOWED' and created the T junction at pins and flagging the DRC.
    Set Ts as 'PINS ONLY' and created T joint at via and flaging the DRC.
    • Vote Up +2 Vote Down
  • Ram1234
    0 Ram1234 over 2 years ago in reply to aniju
    Hi aniju
    Good day!...
    Can you please explan in detail for the below one
    "MICROVIAS_MICROVIAS_ONLY
    MICROVIAS_MICROVIAS_COINCIDENT_ONLY "
    Thanks .
  • aniju
    0 aniju over 2 years ago in reply to Ram1234
    Here are the details.
    MICROVIAS_MICROVIAS_ONLY - its only accepts microvia-microvia direct connections can be formed.
    Constriant set to 'NOT_ALLOWED' overlapping uvia's [micro via defined for 1 to 2 layers] (MICROVIAS_MICROVIAS ONLY) and flagging the drc.
    Constraint set to 'MICROVIAS_MICROVIAS_ONLY',uvia-uvia overlap is not flagging the drc.
    Constriant set to 'MICROVIAS_MICROVIAS_COINCIDENT_ONLY', In this condition, uvias/uvias overlap each other will accepts and it won't flag the DRC.
    here is the image, uVIA overlap is not flaging the drc and other condition flagging the drc because both uvias are not coincidents.
    Please let us know if you have further queries.
