  3. Strange problem with routing
  • Subscribers 159
  • Views 6526
Bejoy Thomas
Bejoy Thomas over 2 years ago
While routing the Ground lines got highlighted in the entire PCB circuit. Pls. find attached screenshot for the same. Any idea what could be the issue? or how to un select the lines.
  • Bejoy Thomas
    strange thing is I can not un select the selected lines. Does anyone face similar situation?
  • B Bruekers
    B Bruekers over 2 years ago in reply to Bejoy Thomas
    This happens sometimes when doing x-highlighting with Capture.  In Allegro: display -> dehighlight, Optionally check the 'Retain objects custom color'  and press 'all'.
    That should do the trick to dehighlight all items.
  • Hoangkhoipcb
    Hoangkhoipcb over 2 years ago
    Hi Bejoy Thomas,
    U try to follow:
    First at all you visible Etch all. Next,
    Logic->net schedule.
    pick net Ground It show you all routing in design.
    I hope help you.
    HoangKhoi.
