  3. Allegro: Tip of the Week – Deleting a via in a stack
  • Subscribers 159
  • Views 6672
TCHA
TCHA over 2 years ago
If you want to delete a section of a stacked via, use the Edit > Delete command and tune your Find filter to Vias. Click on the via that you want to delete to select it.
Now, right-click and select the Split Stack option.
From the popup list, select the layer pair to delete.
  • masamasa
    masamasa over 2 years ago
    i do not see that on my right click menu.
  • TCHA
    TCHA over 2 years ago in reply to masamasa
    Make sure you have the variable 'stacked_via_off' disabled in the User Preference Editor. With the variable enabled, you will not get the Split Stack option in the RMB menu
  • masamasa
    masamasa over 2 years ago in reply to TCHA
    thank u
    it worked.
    it is a nice feature.
