  3. MANUFACTURING/SHAPE PROBLEMS circle meaning ?
  • State Suggested Answer
  • Answers 2
  • Subscribers 159
  • Views 2020
SOT23
SOT23 over 2 years ago
Whuile designing a top/bottom layer GND shape, I encountered something I had never seen to this date, a yellow circle figure on the Manufacturing/shape problems layer :
This is bottom layer. Internal layers are either tracks or planes. There is no apparent "problem" with the shapes. Spacing is ok, minimum aperture width is ok...
When I click "info" on the circle, it doesn't give me any indication on what is going wrong...
Anyone know what that means ? I found a doc by parallel system that tries to explain it but it doesn't seem to make much sense in this case.
This is with OrCAD PCB Editor Pro 17.4 on Windows.
  • B Bruekers
    0 B Bruekers over 2 years ago
    "manufacturing/shape problems" is not a default subclass from Allegro.
    With other words, this is most likely generated by some 3rd party tooling doing certain shape checks.
  • SOT23
    0 SOT23 over 2 years ago in reply to B Bruekers
    Really ?! This is really strange as, as far as I am aware, there is no 3rd party software installed...
    I am going to ask our distributor if they know about that, maybe they add things in the files they send us...
    Thank you !
  • DavidJHutchins
    0 DavidJHutchins 4 months ago in reply to SOT23
    This is generated by the Cadence command 'shape check', below is the documentation:
    Shape Check
    Shape – Check executes legacy code that works on a single shape at a time. It’s most useful on a shape that fails to run through Gerber 4x or 6x, but not as relevant for raster artwork. In theory, a vector-based dynamic shape should process without problems, but a mix of user-added and dynamic-generated voids might cause issues, along with user-defined void patterns that are too close to each other or have edges that the Minimum Aperture field (defined in the Global Dynamic Shape Parameters dialog box) could not outline.
