  3. Skill axlZoomFit usage
  • State Verified Answer
  • Subscribers 159
  • Views 5833
Jim OMahony
Jim OMahony over 2 years ago
Hi, I am trying to use the axlZoomFit command with an env shortcut to zoom out to the sheet border of my design.
Here is the code that I am trying:
axlCmdRegister( "ZoomFitVisible" `ZoomFitVis ?cmdType "interactive")
(defun ZoomFitVis () axlZoomFit(0 visible)')
I have substituted a random command to check for typos, the following works fine to flip the view.
(defun ZoomFitVis () axlDesignFlip( !axlDesignFlip()))
After trying various modifications I am having no success with this command. Any coding gurus got a solution ?
Jim O'Mahony
  • DavidJHutchins
    +1 DavidJHutchins over 2 years ago
    You have the single quote in the wrong location, try the following:
    (defun ZoomFitVis () axlZoomFit(0 'visible))
  • Jim OMahony
    0 Jim OMahony over 2 years ago in reply to DavidJHutchins
    Thanks david. I just blindly copied the skill reference file typo :-)
