  3. eagle import
  • State Suggested Answer
  • Answers 2
  • Subscribers 160
  • Views 6977
eagle import
JuriV
JuriV over 2 years ago
Hi everybody,
a want to import eagle brd. file in to orcad PCB Designer using File -> Import -> CAD Translators -> Eagle PCB.
The Error "*Error* close: argument #1 should be an I/O port (type template = "p") - nil" appears.
Everybody knows this problem and how to solve it?
JuriV
  • John T
    0 John T over 2 years ago
    Hi JuriV, we have been in direct contact via email in order to explore this issue further.
  • John T
    Hi JuriV, in summary to help others: The Issue was resolved. The translator can be launched using command window entry "ns_eagle2allegro”. This tool was created prior to OrCAD and Allegro 16.6 and is therefore supplied only as is using this command. The revision of  nsWare (2.38)  was also updated, replacing the nsWare directory in the ILINIT file using load("D:/Cadence/Allegro/skill_data/nsware.il" "nsware")
  • jc teyssier
    0 jc teyssier over 2 years ago
    try to replace <install_dir>tools\capture\tclscripts\capEagleImport\capEagleImport.tcl with this one: works for me.capEagleImport.zip
