  3. How do you use allegro_uprev to update .dra padstacks, etc...
  • Subscribers 160
  • Views 6393
How do you use allegro_uprev to update .dra padstacks, etc.? I need to update my library, and using DBdoctor is a little tedious.
Nilanjan Talukder
Nilanjan Talukder over 2 years ago
I am trying to update my library for newer design and using DBdoctor to update .dra and padstack is tedious. How can I use allegro_uprev for this? Looking for documentation and examples for the same.
Nilanjan
  • oldmouldy
    0 oldmouldy over 1 year ago
    DB Doctor, allegro_uprev supports wild cards so you can browse to a DRA file in the library folder, edit the filename value to end "\*.dra", then repeat that for compiled symbols, "\*.?sm" and finally the pad files, "\*.pad" and all of the files in the folder with those types will be updated.
