  3. How to fix this error when I trying to export the ODB++...
  • Subscribers 160
  • Views 7687
How to fix this error when I trying to export the ODB++ in allegro.
OranuchB
OranuchB over 1 year ago
Hi everyone,
I need to continue design from another designers and I have a problem when I trying to export the ODB++ file.
When I try to run ODB++ inside and select .tgz as the output, all of the ODB++ database output files are dumped to the active directory and
I get a "Translation failed! dml_fsymlib-42004-Illegal symbol dimensions" pop-up and the process can't proceed.
I've generated ODB++ packages on this computer before, so not sure what's changed.
Gerbers generate just fine.  I tried re-installing ODB++ Inside, but that didn't make a difference.
Anyone else know of this error and how to correct it? Please. T_T
  • VVRD
    0 VVRD over 1 year ago
    please try removing flash symbols in the footprint if you've
  • OranuchB
    0 OranuchB over 1 year ago in reply to VVRD
    Thank you for your answer. but I do not create this board file and all libraries. so it is difficult to find it error. T_T
  • jc teyssier
    0 jc teyssier over 1 year ago
    Be aware to not have space or special characters (such èé&) in the brd path or name: some programs does not handle this it correctly
