  3. Limit specific BRD files to only using certain library paths...
  • State Verified Answer
  • Replies 7
  • Views 9818
Limit specific BRD files to only using certain library paths?
bengelJF
bengelJF over 2 years ago
I'm repackaging an existing design from an outside group and have received a schematic and footprint/padstack files.
By pure coincidence, some of the footprint names in the schematic matched up with our internal libraries and were placeable in the board file straightaway. However, I don't want this file to be able to access our internal libraries; I want it to only pull from a particular project-specific library.
I hop between projects pretty regularly, so I don't want to delete everything from my padpath and psmpath to limit my entire installation to the project-specific library. If I do this, I'd have to change them every time I hop to a different board, which could be multiple times a day.
Is there a way to tell a board file to only use specific libraries/file paths?
  • bengelJF
    bengelJF over 2 years ago +2 verified
    The solution we came up with was to use a relative path in the same directory as the .BRD file, e.g. "./Library", placed at the top of the padpath and psmpath lists. OrCAD goes through these lists from…
  • John T
    John T over 2 years ago +1 verified
    Hi bengelJF, it is possible to place a brief SKILL file inside each design folder; in this file you can rewrite the library paths automatically when the design is opened. This SKILL file is to be located…
  • bengelJF
    0 bengelJF over 2 years ago in reply to John T
    I'll verify this as the answer since it's a good way to handle it through scripting. For those reading in the future, we came up with a way to handle this without scripting; see my response below.
  • John T
    0 John T over 2 years ago in reply to bengelJF
    Ok glad you found a solution that works for you. Wishing you every success in your projects.
