  3. Use axlDBCreateExternalDRC to create DRC & get the real...
  • State Suggested Answer
  • Answers 1
  • Subscribers 159
  • Views 1370
Use axlDBCreateExternalDRC to create DRC & get the real value
ivy372
ivy372 over 1 year ago
I want to create the DRC markers,
I use axlAirGap get the gap value.
Skill > space = axlAirGap(x y nil 'enhanced)
=> (nil isEtch t layer2 "PIN/TOP" layer1 "PIN/TOP" location1 (68.25 7.9) location2 (62.925 8.7) airgap 5.384759)
Skill > space->airgap
=> 5.384759
Now I want the DRC marker also can show the actual value, but I still get the error.
(foreach x SYM_GFP_Top
  (foreach y SYM_othP_Top
      airgap = space->airgap
         (if airgap < 2 then
           axlDBCreateExternalDRC( "Gap < 2mm." y~>xy "TOP" list(y) nil space->airgap))
error message
How can I get the actual value on the DRC ERROR CLASS
Thanks~
  • DavidJHutchins
    0 DavidJHutchins over 1 year ago
    Below is an example that works for me:
                            (Result = axlAirGap(item pin "TOP"))
                            when(Result
                                when(listp(Result) && eq(length(Result) 3)
                                    (Result = caddr(Result))
                                when(lessp(Result 7.0)
                                    (Result = sprintf(nil "%f" Result))
                                    (DataList = list(SubClass "7.0"))
                                    axlDBCreateExternalDRC(DataList pin->xy Class list(pin item) nil Result)
                                    (DrcCnt++)
  • eDave
    0 eDave over 1 year ago
    I would replace the command with something like this:
    axlDBCreateExternalDRC(list("Gap", "2mm", "My 2mm Gap"), y->xy, "TOP", list(x, y), x ->xy, lsprintf("%g mm", space->airgap))
    Note that the last argument must be a text value
