  3. distance to fillets (teardrops)
  • State Suggested Answer
  • Replies 9
  • Answers 1
  • Views 10100
masamasa
masamasa over 2 years ago
hello:
is there a way to find out a distance between objects and a fillet?
  • DE202408202727
    DE202408202727 over 2 years ago +1
    A fillet is a shape.
  • VVRD
    VVRD over 2 years ago in reply to masamasa +1 suggested
    Can you try this?
  • VVRD
    0 VVRD over 2 years ago in reply to masamasa
    You can tweak around Max Offset value in Fillet Options section.
  • masamasa
    0 masamasa over 2 years ago in reply to VVRD
    thank u for your reply.
    how can i catch drc spacing violations between fillets and other objects without adjusting the fillet size?
    if i am deadling with my design, i can adjust the fillet size.
    but i have to deal with many designs which are done by our customers, so i would like to catch the drc fillet spacing violation on their designs.
    regards
    masa
  • VVRD
    Can you try this?
  • masamasa
    hello vvrd
    thank u for ur reply.
    it did not work.
    i set the same net spacing as 2um on the constraint manager.
    the spacing between a fillet and a cline is 1.92um.
    but it gives me no error even if i turn on the "eneble line based chack for fillet" on the anaysis mode and update the drc.
    regards
    masa
