  3. Copy Clines Creates DRC
  • State Verified Answer
  • Replies 8
  • Subscribers 168
  • Views 8034
PK20240920135
PK20240920135 over 2 years ago
Since i have to route 300 pairs. I opted to copy paste the clines since they are the exact same length. See below.  The segment that was copied complains. for " Line to through pin Spacing" .
But when i route it manually i see no such DRC.  Is there any way around this or any tips for a scenario where i need to route the same length over and over.. What would you guys do in this case ?
  • DavidJHutchins
    DavidJHutchins over 2 years ago in reply to PK20240920135 +1
    When copying clines I have found that I get better results by making sure that snapping the endpoint to a pin or via to get the net assignment
  • Wild
    Wild over 2 years ago in reply to avant +1
    Have you tried derive connectivity? This helps me when copying groups of symbols, clines and vias. Only issue I've had is I need to delete gnd if there is one on an inner layer first.
  • excellon1
    excellon1 over 2 years ago in reply to avant +1 verified
    There is a fairly easy way to do this based on location and using the pick tool. Assuming your board origin is 0,0 bottom left of your board here are the steps. 1 Find the exact location of the new…
  • PK20240920135
    0 PK20240920135 over 2 years ago in reply to excellon1
    Thank you very helpful. This works well for a single copy. I did a show element on 2 pins and subtracted the Y value to find the exact vertical difference for a copy of more than 1 cline. For some reason the first 2 positions are copied well but not the rest even though they are part of the same command. Anyways i dont want to trouble you guys anymore i think i have enough to work with.  Thank you everyone !
  • excellon1
    +1 excellon1 over 2 years ago in reply to PK20240920135
    Hi Pk..
    Glad that works for you. I have found here it is very handy to copy dif-pair pin exits. For example on your design that has the etch
    wrapping around a pin another approach would be to copy the cline but then trim back that etch just to include the pin exits only
    first, then manually route in the connections to join things up.. Its fairly trivial to route in a straight line but doing the pin exits
    so there is some sort of consistency in particular if doing curved etch can be challenging on a pin pair basis.
    All the Best.
  • PK20240920135
    You truly are an Excellon ! :) Thank you again you have been very helpful.
