  3. How to Assign a Hotkey for "Temp Group" in Allegro Using...
  • Subscribers 160
  • Views 565
How to Assign a Hotkey for "Temp Group" in Allegro Using ENV File?
VK202506218248
VK202506218248 5 months ago
Hi everyone,
I'm trying to assign a hotkey to activate the Temp Group option in Allegro (version 23.1), using the ENV file. I wrote the following line:
funckey t "prepopup;pop dyn_option_select 'Temp Group'"
However, pressing t during commands like Copy or Move (where Temp Group normally appears in the right-click menu) doesn't trigger anything.
I understand that Temp Group is context-sensitive and only appears during certain operations, but I was hoping it could be triggered similarly to other dynamic options like:
funckey p "prepopup;pop dyn_option_select 'Snap pick to@:@Pin'"
So my questions are:
  • Is it technically possible to assign a hotkey to Temp Group?
  • Is my syntax incorrect, or is Temp Group simply not accessible via dyn_option_select?
  • Are there any workarounds or SKILL-based methods to simulate this behavior?
Thanks in advance!
TRANSLATE with x
English
Arabic Hebrew Polish
Bulgarian Hindi Portuguese
Catalan Hmong Daw Romanian
Chinese Simplified Hungarian Russian
Chinese Traditional Indonesian Slovak
Czech Italian Slovenian
Danish Japanese Spanish
Dutch Klingon Swedish
English Korean Thai
Estonian Latvian Turkish
Finnish Lithuanian Ukrainian
French Malay Urdu
German Maltese Vietnamese
Greek Norwegian Welsh
Haitian Creole Persian
TRANSLATE with
COPY THE URL BELOW
Back
EMBED THE SNIPPET BELOW IN YOUR SITE
Enable collaborative features and customize widget: Bing Webmaster Portal
Back
  • AsbjornEdvalds
    AsbjornEdvalds 5 months ago
    A very nice way of writing and figuring out what hotkeys do is by letting the tool print out all the items you are doing into the command line. This can be done by using the scriptmode +e command. This can then be turned off by calling scriptmode -e
    When this has been invoked, it can be seen that pressing the Temp Group button when doing a copy calls a group command. I therefore assume that your hotkey assignment could be as simple as the following:
    funckey t group
    Hope this helps
