  3. Idea for improvement with file-import-logo feature
  • Replies 7
  • Subscribers 167
  • Views 5716
gvellet
gvellet over 1 year ago
The file-import-logo feature is accessible in the symbol editor of Allegro/Orcad PCB editor. It is old and improvements would be appreciated.
The feature accepts only bmp file. It convert the logo shapes into lines that can be assigned to a layer such as silkscreen. The problem is that when it converts bitmap shapes into lines, it often destroys the the logo. When Orcad tries to figure out the outline of complex shapes in the bitmap file, it creates self intersecting lines. My request is that the logo import feature should offer the option to directly convert the bitmap into shape without going through line first. As an example, I was trying to convert a QR code into a mechanical symbol using the import logo, but it destroys the code with self-intersecting lines preventing the use of shape-compose function.
  • Eric Jordan
    Eric Jordan over 1 year ago +1
    +100
  • Gowtham P
    Gowtham P over 1 year ago +1
    Hi gvellet , Eric Jordan Thanks for sharing your suggestion. This request has already been raised with the Cadence R&D team, and your feedback has been noted.
  • excellon1
    excellon1 over 1 year ago +1
    Hi. I have had good success with logos if they are in DXF format. Perhaps that may be worth trying as an option for import. Best regards.
  • JM20241029170
    JM20241029170 6 months ago
    In OrCAD 25.1, the Import->Logo feature is missing. Running OrCAD Professional Plus 25.1
  • JM20241029170
    JM20241029170 6 months ago in reply to JM20241029170
    Just found it when I created a new mechanical symbol. The tutorials out there are very unclear on that requirement.
