  3. Issue with Via-Via Constraints
  • State Verified Answer
  • Replies 10
  • Subscribers 168
  • Views 7327
WG20250730781
WG20250730781 over 1 year ago
Hi all,
I have an issue with the via-via constraints of my design.
1. Normally, the via-via distance is defined in the constraints manager. However, the thru via to thru via spacing is defined by the air gap between the two vias. The issue is that this air gap accounts for the pad size to pad size distance of the via, and not the hole-to-hole distance itself. Often in manufacturing, hole-to-hole distance is more important in fabrication. How do I account for actual hole-to hole distance itself?
2. Under the constraints manager, there is a column that specifies 'hole to hole'. When I double click it, it pops up another window and further classifies into so many other line items:
However, under the general constraints manager window, there is already 'Thru via to Thru via'. How are these two different?
I appreciate some professional help.
Thank you.
  • WG20250730781
    WG20250730781 over 1 year ago +3 verified
    I found the solution. After much exploration and research, I stumbled upon a quick-and-easy solution. Under Setup -> Constraints -> Modes The Analysis Modes Window will pop-up. Then, under the Design Tab…
  • excellon1
    excellon1 over 1 year ago +1 verified
    Hi In Allegro there is the option to do Hole to Hole checking of various objects such as vias etc. Typically this analysis mode is not enabled in the constraint manager and would need to be enabled. To…
  • WG20250730781
    0 WG20250730781 over 1 year ago in reply to excellon1
    Hi all, so what I'm getting from this discussion is this:
    - If I want to set up hole-to-hole constraints, then I need to enable pad suppression (only works for inner layers)
    - This will effectively remove all the pads that are unused and the hole-to-hole constraint will then take effect as I intended.
    - But all the pads will be removed (not intended).
    If the pads are still present, no matter what, it will ALWAYS override the hole-to-hole constraint.
    (Is this true? If so, then there is no physical way to set up hole-to-hole clearance WITHOUT removing the pad itself, right?)
  • avant
    0 avant over 1 year ago
    We have the same issue.
    We have the second-tier Allegro license.
    My work-around is to calculate the via pad-to-pad clearance taking into account the desired hole-to-hole distance.
    Usually, all of our via pad diameters are the same, so this works OK.
  • WG20250730781
    +1 WG20250730781 over 1 year ago
    The Analysis Modes Window will pop-up. Then, under the Design Tab, expand the Spacing Options. There will be an option to 'Check holes within pads'.
    Click OK, then you can edit the constraints manager for the specific requirement for hole-to-hole spacing.
    • Vote Up +3 Vote Down
  • excellon1
    0 excellon1 over 1 year ago in reply to WG20250730781
    That's a good find since it works on all layers where a pad exist.
    I can see a good use case for this with BGA's when doing dog bone fannout based on how far away a drill should be from a pad on the same net.
    Best regards.
  • avant
    0 avant over 1 year ago in reply to WG20250730781
    Thanks!
    I've needed this solution for several years.
    Once again, Cadence has made a simple setting require hours of searching for the solution.
