  3. What is the best PCB Editor Command?
  • Replies 20
  • Subscribers 167
  • Views 8317
John T
John T 9 months ago
You may already know how to type function commands directly into the PCB Editor Command panel. This can be a great time saver and performance boost.
We have compiled a list of some of our engineers' favorite commands which we recommend.
Let us know what your favorite commands are?
Any questions, recommendations or other commands you think are more helpful?
So far we gathered the following:
Command                     Explanation
filemgr                              Opens the file explorer in the current design directory
reopen                              Reopens the current design to remove unsaved changes
done                                 Closes current active command
record                               Initiates the recording of a script under a specified name
stop                                  Halts the recording of scripts or macros and closes the .scr file
replay                               Executes a specified script; prompts for a script filename if none is provided
enved                               Opens the User Preferences Editor UI – normally located in the Setup menu
cns cmmodes                   Opens the Constraints Analysis Modes UI
design compare               Opens design comparison ui ( xml netlist version)
set                                    Display a list of all currently defined variables for the session
funckey                            Opens a list of all currently defined Alias Keys and Function Shortcut Keys
(up arrow key)                  Recall the previous command – consecutive use possible
Any more?! Comments or questions appreciated...
  • JCTEYSSIER0
    JCTEYSSIER0 9 months ago +2
    helpcmd -> list all command and provide help on each one oops -> oops, i whish to get back alias -> to define... aliases system -> open a sytem level windows with same environnement that acutal brd…
  • ltoohey
    ltoohey 9 months ago +2
    Maybe a little off topic but... XKeys programmable keypad works good for many of the common commands and especially functions within commands. I use it for all of the snap pick to functions.
  • JCTEYSSIER0
    JCTEYSSIER0 9 months ago in reply to John T +1
    yes but i prefer alis i create long time ago: alias x pick alias y picky alias ix ipick alias iy ipicky verry handly for me and quick
  • John T
    John T 9 months ago in reply to Robert Finley
    That really sounds top class Robert!
    So you are able to program the pcb editor script commands directly to each mouse button - or how does that work?
  • Robert Finley
    Robert Finley 9 months ago in reply to John T
    Keyboards and mice appear to share a common UI mechanism.
    Logitech includes a device driver that you use to define the text strings you want to be sent when pressing a button.  I use the feature to map pressing the scroll wheel to a side button.  Less fatigue that way.
    The Logitech G502 Hero edition isn't wireless (which I never use.) but it has 11 buttons including the typical three.
    If you want 2, 6, or 12 buttons at your thumb, there is the Razer Nagra V2 Pro.
    I store command strings inside the mouse for playback, but that isn't necessary with the Logi drivers.
    Side note:  consider using a short Allegro command alias on the mouse macros.  If you're sipping coffee and watching your coworkers fight it out on Slack, hitting your "placementedit" command button is one way to steal the spotlight.  You just slack-sent that string to everyone in the company.
    Logitech allows you to go the extra effort and define program-specific set of macro strings that gamers expect.  Macro config changes depending on what program you're focused on.
    Still trying to wear out my current Logitech mice.  Gamers are heavy duty, apparently.
  • Robert Finley
    Commands I wish I had:
    • zero'ing out a non-45 or orthogonal symbol rotation angle after a mishap with the spin command.
    • Switching between move (groups) by a selection point or move symbol by origin.
  • DavidJHutchins
    DavidJHutchins 9 months ago in reply to John T
    One that I use frequently is the 'filemgr' command, which is basically undocumented
    The default is to open on the current design's directory, however it will also open the browser on other folders:
    'filemgr c:/temp' &' filemgr c:\temp' both work on Windows machines...
  • Robert Finley
    Robert Finley 9 months ago in reply to DavidJHutchins
    Love that.
    I've been navigating to C:\SVN\Hardware for ten years...
    Have a solo Allegro X license.
    Launch the command, quit the current instance and launch a new one with the new file.
    Thank you!
