  3. What is the best PCB Editor Command?
  • Replies 20
  • Subscribers 167
  • Views 8335
John T
John T 9 months ago
You may already know how to type function commands directly into the PCB Editor Command panel. This can be a great time saver and performance boost.
We have compiled a list of some of our engineers' favorite commands which we recommend.
Let us know what your favorite commands are?
Any questions, recommendations or other commands you think are more helpful?
So far we gathered the following:
Command                     Explanation
filemgr                              Opens the file explorer in the current design directory
reopen                              Reopens the current design to remove unsaved changes
done                                 Closes current active command
record                               Initiates the recording of a script under a specified name
stop                                  Halts the recording of scripts or macros and closes the .scr file
replay                               Executes a specified script; prompts for a script filename if none is provided
enved                               Opens the User Preferences Editor UI – normally located in the Setup menu
cns cmmodes                   Opens the Constraints Analysis Modes UI
design compare               Opens design comparison ui ( xml netlist version)
set                                    Display a list of all currently defined variables for the session
funckey                            Opens a list of all currently defined Alias Keys and Function Shortcut Keys
(up arrow key)                  Recall the previous command – consecutive use possible
Any more?! Comments or questions appreciated...
  • JCTEYSSIER0
    JCTEYSSIER0 9 months ago +2
    helpcmd -> list all command and provide help on each one oops -> oops, i whish to get back alias -> to define... aliases system -> open a sytem level windows with same environnement that acutal brd…
  • ltoohey
    ltoohey 9 months ago +2
    Maybe a little off topic but... XKeys programmable keypad works good for many of the common commands and especially functions within commands. I use it for all of the snap pick to functions.
  • JCTEYSSIER0
    JCTEYSSIER0 9 months ago in reply to John T +1
    yes but i prefer alis i create long time ago: alias x pick alias y picky alias ix ipick alias iy ipicky verry handly for me and quick
  • John T
    John T 9 months ago in reply to Robert Finley
    No problem!
  • John T
    John T 9 months ago in reply to excellon1
    Great insights excellon1, thanks so much for sharing!
    Yes and totally agree that mouse strokes can also be a huge time saver when mastered for pcb design. After using them for about 10 years, I found myself sharing the burden between left and right hands though. Some commands I would use the mouse strokes (left hand), and for others I was using the right which was hovering over the keyboard. Like a wax-on / wax-off dual-handed approach!
    More elaborate strokes can be slower than a keyboard press, or need to be repeated. So once all the simple strokes are allocated, it may be more efficient to use the command autotype or an alias for later commands. Just a thought. :)
  • John T
    John T 9 months ago in reply to ltoohey
    Oh wow, that's a really fantastic idea - thanks Itoohey! I have not seen these used for CAD / EDA before.
    So these are the usb peripherals with a grid of maybe 24 x illuminated square buttons or so, is that correct? I believe they were originally designed for music performance - correct me if I am wrong. What prompted you to try that approach?
  • ltoohey
    ltoohey 9 months ago in reply to ltoohey
    Here is a picture of the mappings I have on my x-keys
    The top row is the same a function key F1-F10
    The second row is the same as Shtft-F1-Shift-F10
    The left group is for shape edit functions.
    The middle group is for snap pick to functions
    The right group is for etch edit/routing modes - it tried to map a key to ever pick in the add-cline window.
    Well, the forum tools will not let me add a picture showing the mappings I have.
    See the k-keys tool Here. I find that the XK-60 is good for size and number of functions...
    https://piengineering.com/products/xk60
    Whatever you do, do not map a key to Alt-F4... Wink
  • John T
    Excellent Itoohey! Well this is one sure way to give yourslef "rock-star vibes" while designing pcbs!! ThumbsupThumbsup
    By the way, you should be able to upload a saved image using the insert > image button in the comments interface. We had some fixes done on this by our IT group recently. Bitmap files may work best.
    I would be interested to see if this lights up? And are you able to color code these to help easily differentiate between the various commands?
