  3. Skill code to move component
  • Replies 34
  • Subscribers 167
  • Views 40588
archive over 20 years ago
I'm trying to generate a skill program that launches place manual -hide and then picks a specific coordinate to pick up the component placed in that coordinate.
I know that I have a pin placed in 0,0 and would like the skill program to pick that coordinate and leave the component on the mouse for me to place manually.
I've tried doing the following
axlShell("place manual -h")
axlShell("pick 0 0")
and I've also tried running a script that I've recorded that does the exact same, but both methods fail. They do launch the place manual command but I cannot get skill to pick that coordinate so that it is left for me to move the component
Does anyone have some good ideas, thanks.
Best regards,
Ole
Originally posted in cdnusers.org by ejlersen
  • Quarkdog1
    Quarkdog1 over 14 years ago
    Hi Dave,  I just started using the "find_cmp.il" to me out but  the moveByRefdes command somehow alters the "designator case".  The find_cmp will work with "c1" designator but after I use the moveByRefdes, then I need to use "C1".  moveByRefdes will toggle it back to "c1" after the next use.  Any ideas what might be causing this?
     Thanks a bunch in advance.
  • DE202408202727
    DE202408202727 over 14 years ago
    I'll publish some improved code shortly but,in the meantime, add the following line:
    refdes = sym ->name
    below the line :
    sym = car(axlSelectByName("SYMBOL", refdes))
    My designs don't contain lower case reference designators so I had overlooked the possibility of their use.
  • DE202408202727
    Oops, Of course that command should be:
    refdes = sym ->refdes
  • Quarkdog1
    The code change below caused an issue ( part disappeared )
    W- *WARNING* (axlDBCreateSymbol): Refdes not found - "ID004D"
    Mark
  • DE202408202727
    Yep, sorry about that - see the correction above!
