  3. How to check the mistaken Reference Text location
  • Replies 21
  • Subscribers 161
  • Views 24456
archive over 19 years ago
How to check the mistaken Reference Text location during arranging the silkscreen?
For example, the component R1 is close to R2, but the Text: R1 and Text: R2 have been exchanged their location. But Allegro can't check them out.
How deal with this situation by SKILL or other solution?
Originally posted in cdnusers.org by leonlee
    Hi Leon,
    Have you used the autosilkUtils.il code. It does that (and much more).
    Cheers, Dave
    Originally posted in cdnusers.org by Dave Elder
    Hi, Dave,
    I havn't use the routine: autosilkUtils.il. Is it written by you or Candece original function?
    Hi Leon,
    I wrote it. Download it from the Allegro Skill Code area on sourcelink.
    (Look for "Silkscreen violation checking" utility)
    Cheers, Dave
    archive over 18 years ago
    Hi Dave
    i have been using your silkutils skill code for some time and would like to change some of the default setting to make it a bit quicker, could you tell me how to do the following ( if thats OK by you) turn off Reference Des Locations, Solder mask on vias and set the default value to 5 in the boxes
    This is to help speed up the checking in Valor.
    Cheers, Roger
    Originally posted in cdnusers.org by roger.green@alspcb
    Hi Roger, Edit the Skill file and change the following: To turn off Reference Designator Locations: In line 505 change the following line from: ASU_toggleField(form, "textloc", car(objectsExist)) to: ASU_toggleField(form, "textloc", nil) To uncheck Solder Mask Pads on Vias: In line 285 change the line: if(viaResist then when(ASU_checkVias, axlFormSetField(form, "vias", t)) else axlFormSetFieldEditable(form, "vias", 0)) axlFormSetField(form, "vias", nil), unless(viaResist, axlFormSetFieldEditable(form, "vias", 0)) To set the spacing defaults to 5 mils: search and replace on the following text that appears in three locations: axlMKSConvert(10, "mils") Change to axlMKSConvert(5, "mils") Note: These values are stored in the design - so if the utility has been run with 10 mils - that will still be the number that is in the booxes. Let me know if you have any problems. I can send you the modified code if you like. Cheers, Dave
