  3. Dynamic Shape Parameters
  • Subscribers 159
  • Views 13298
archive over 18 years ago
Does anybody know if I can display or change Dynamic shape Parameters of shapes (oversize clearance value etc.) with skill, in Allegro 15.5? It doesn't seem like you can do it, but I may be looking in the wrong place. - Geoff
Originally posted in cdnusers.org by Geoffm
  • GIL2004XP
    GIL2004XP over 13 years ago
    I find this achievable by using script as codes below;
    "FORM dyn_xshape thru_pin_clear_drc 5" if you want to set 5 mils as oversize value
    "FORM dyn_xshape smd_pin_clear_drc 5" if you want to set 5 mils as oversize value
    "FORM dyn_xshape via_clear_drc 5" if you want to set 5 mils as oversize value
    "FORM dyn_xshape line_clear_drc 5" if you want to set 5 mils as oversize value
    "FORM dyn_xshape text_clear_drc 5" if you want to set 5 mils as oversize value
    "FORM dyn_xshape shape_clear_drc 5" if you want to set 5 mils as oversize value
    These codes were extracted by entering "scriptmode +e" in Command Line
