  3. axlDBAltOrigin
  • Subscribers 159
  • Views 12559
axlDBAltOrigin
archive over 17 years ago
I am attempting to using axlDBAltOrigin to eventually extract the X and Y coordinates of a components origin which is selected by a mouse click. After looking thru example code and documentation, my attempt is still incorrect. Would someone be willing to offer a beginner advice as to what I am doing wrong? Thank you. The code: axlClearSelSet() axlSetFindFilter( ?enabled list("noall" "Components") ?onButtons list("Components") ) axlSelect( ?groupMode nil ?prompt "Please Select Component" ) sym = axlGetSelSet() axlShowObject(axlGetSelSet()) comp_origin = axlDBAltOrigin('origin sym) xcoord = car( comp_origin) ycoord = cadr( comp_origin) axlMsgPut("X location is %s", xcoord) axlMsgPut("Y location is %s", ycoord)
Originally posted in cdnusers.org by Lcan
    the origin of a component is not stored directly with the component object but rather 'beneath' it with the associated symbol object.
    comp_db = nil
    axlClearSelSet()
    axlSetFindFilter( ?enabled (list "noall" "COMPONENTS") ?onButtons (list "COMPONENTS"))
    comp_db = car( axlGetSelSet( axlSingleSelectPoint()))
    axlCloseFindFilter()
    axlClearSelSet()
    comp_origin = comp_db->symbol->xy
    printf("component %s -- X:%n Y:%n\n", comp_db->name xcoord ycoord)
    HTH,
    Chris Walters
    local Cadence guru
    Originally posted in cdnusers.org by kerchunk
    This does help. My apologies for the poor formatting in the original message. Thank you for your help, it is appreciated. Bill
