  3. How to Find the location missing of assembly component subclass...
  • Replies 11
  • Subscribers 18
  • Views 16136
How to Find the location missing of assembly component subclass BY SKILL.
DDRsvi
DDRsvi over 8 years ago
Some issues design appear when I completed and check overall before releasing my design. And I need to check on ASSEMBLY which it is missed by created manual of designer.
Dear Mr Dave and all members of Cadence forum. Please support me to get ideal to check the missing of assembly components.
BTW, Please comment on this case: I used "axlRunBatchDBProgram("extracta" tCmd ?silent t ?noUnload t ?reloadDB nil)" cmd BUT It use big template data (> 30Gb to extract database). The extracted field is PIN, NET. I try to just extract on NET but the tepmplate data still is big.
Hope your reply!
DDRsvi,
  • DE202408202727
    DE202408202727 over 8 years ago +1
    I'm not sure what you are asking. You say ASSEMBLY is missing. Do you mean the assembly outline of a component, a reference designator, a layer from a mask or something else? Extracts can be big. I tend…
  • DE202408202727
    DE202408202727 over 8 years ago in reply to DDRsvi +1
    Try something like this: defun( DE_AssemblyCheck () foreach(sym, axlDBGetDesign() ->symbols unless(exists(obj, sym ->children, memv(obj ->objType, '("path", "shape", "polygon")) && obj ->layer == strcat…
  • DE202408202727
    unless(exists(obj, sym ->children, memv(obj ->objType, '("path", "shape", "polygon")) && obj ->layer == strcat("PACKAGE GEOMETRY/ASSEMBLY_", if(sym ->isMirrored, "BOTTOM", "TOP")))
    silkObjs = setof(obj, sym ->children, memv(obj ->objType, '("path", "shape", "polygon")) && obj ->layer == strcat("PACKAGE GEOMETRY/SILKSCREEN_", if(sym ->isMirrored, "BOTTOM", "TOP")))
    when(silkObjs
    newObjs = axlCopyObject(silkObjs, ?move 0:0)
    axlSymbolAttach(sym, newObjs)
    axlChangeLayer(newObjs, strcat("PACKAGE GEOMETRY/ASSEMBLY_", if(sym ->isMirrored, "BOTTOM", "TOP")))
  • Gowtham229
    Gowtham229 over 7 years ago in reply to DE202408202727
    hi dave,
    report file is not getting generated please help me by adding the same & please upload .il file
  • DE202408202727
    DE202408202727 over 7 years ago in reply to Gowtham229
    Something like this?
    p = axlDMOpenLog("AssemblyCheck")
    when(silkObjs
    fprintf(p, "%s (%s) updated\n", sym ->refdes, sym ->name)
    axlDMClose(p)
    axlUIViewFileCreate("AssemblyCheck.log" "Assembly Check", t)
  • Gowtham229
    Hi dave,
    Thank you very much for the code I'll execute in Allegro and let you know. I have one doubt can I use command axluiviewfilecreate to generates logs for other skills also.
    Gowtham
  • DE202408202727
    Yes. If you have created a log file.
