  3. skill for changing trace width in particular region
  • Replies 13
  • Subscribers 18
  • Views 17744
Gowtham229
Gowtham229 over 7 years ago
Hi can any one help provide the skill file for changing trace width in pcb using skill file.Currently i have skill file which can change trace width by selecting layer, existing trace width to new trace width .but for example if i have 5mils trace width in layer 5 it was changing in entire board file. i just want to select only particular region in PCB to change trace width which should not effect other traces. please let me know if any one can help with skill file.
Gowtham
  • DE202408202727
    DE202408202727 over 7 years ago in reply to Gowtham229 +1
    Before I do this... You do realise that this can be done using the Edit/Change menu now?
  • Gowtham229
    Gowtham229 over 7 years ago in reply to Gowtham229
    Hi dave im using 22layer PCB where the new skill sent by you is not showing any source segment current trace width or area to change.please let me know whether im using any option wrong
  • DE202408202727
    Try this
    https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/28/2045.DE_5F00_cwidth.zip
  • Gowtham229
    Gowtham229 over 7 years ago in reply to DE202408202727
    Working perfectly even we can use temp group option.Thank you very much dave for the code..!!
    Gowtham
