  3. Skill code to Calculating PCB Real-estate usage using placement...
  • Replies 8
  • Subscribers 28
  • Views 17276
Skill code to Calculating PCB Real-estate usage using placement boundaries and package keep ins
Toolman
Toolman over 6 years ago
Other tools allow a sanity check of placement density vs available board space.  There is an older post "Skill code to evaluate all components area (Accumulative Place bound area)"  (9 years ago) that has a couple of examples that no longer work or expired.
This would be useful to provide feedback to schismatic and project managers regarding the component density on the PCB and how it will affect the routing abilities.  Thermal considerations can be evaluated as well
Has anyone attempted this or still being done externally in spread sheets?
  • dote4
    dote4 over 5 years ago in reply to joma +1
    Any other script? Joma?
  • jgregoire
    jgregoire over 4 years ago
    I have not tried doing this in SKILL, but as a Linux user, I came up with another solution.
    1. Quickplace all parts
    2. In color dialog, hide everything except the PLACEBOUND shapes.
    3. Select all visible shapes, run Show Element. Save the output as a text file. Buried in this huge report is an area measurement of every shape. You wouldn't want to add these manually, but that's what shell scripting is for!
    4. Run this command in a Unix environment: $ grep -w Area shape_area.txt | sed 's/.* \(0\.[0-9]*\) .*/\1/' | awk '{s+=$1} END {print s}'
    5. Compare the resulting area number to the area of the PLACE_KEEPIN box.
    Works in Linux, Cygwin, git-bash, WSL, whatever you have available to you.
  • AvengerThanos
    AvengerThanos over 4 years ago
    You could try placement density analysis in OrCAD PCB editor
  • jgregoire
    jgregoire over 4 years ago in reply to AvengerThanos
    Can you elaborate?
