  3. Allegro shell command
  • Subscribers 18
  • Views 9369
Cadencer
Cadencer over 4 years ago
Hi!
I have a trouble with the Allegro. I wonder how to use the Allegro command in skill code.
Specifically, I want to open a brd.file through a skill file.il.
Is there a command to open a brd.file through a skill code?
Another question is, can I use a shell for the Allegro?
I want to put commands in a shell like skill.il. I hope that through I do not directly put commands in the Allegro, I could give the Allegro commands.
Best regards
Thank you!
  • DavidJHutchins
    DavidJHutchins over 4 years ago
    Regarding your first question - look at the documentation for the function axlOpenDesign()
  • Cadencer
    Cadencer over 4 years ago in reply to DavidJHutchins
    Thank you!
    More question, how can I open a design to read mode? It just has a write mode..
    Cheer.
