  3. Adding Filled Pads and filled shapes into my dxf output...
  • State Verified Answer
  • Subscribers 20
  • Views 7816
Adding Filled Pads and filled shapes into my dxf output file through skill script
ashishya
ashishya over 3 years ago
I got the script for DXF generating of individual artwork written by @B Bruekers script is as follows-
l_cnvFiles = nil
designName = axlCurrentDesign()
foreach(filmName axlGetParam("artwork")->groupMembers
f = strcat("DXF_" filmName)
p = axlDMOpenFile("ALLEGRO_CNV" f "w")
fprintf(p "#This is the Layer Conversion File used for\n")
fprintf(p "#importing DXF data into Allegro/APD.\n\n")
fprintf(p "#CLASS!SUBCLASS!DXF_LAYER!\n\n")
foreach(layer axlGetParam(strcat("artwork:" filmName))->groupMembers
layerStr = parseString(layer "/")
fprintf(p "%s!\n%s!%s!\n\n" car(layerStr) cadr(layerStr) strcat(car(layerStr) "_" cadr(layerStr)))
fprintf(p "#END\n")
push(get_filename(p) l_cnvFiles)
axlDMClose(p)
sprintf(cmd "a2dxf -$ -u MM -a 4 -f 14 -c L \"%s.cnv\" \"%s/%s_%s.dxf\" %%s" f getWorkingDir() designName filmName)
axlRunBatchDBProgram("Creating DXF File" cmd ?warnProgram t ?noExitMsgs t)
errset(mapcar('deleteFile l_cnvFiles) t)
but I need to add two more option into the a2dxf function which are "export filled pads & fill solid shapes and rectangles" as per below pic-
 can someone help me how can i do that?
  • DE202408202727
    DE202408202727 over 3 years ago +1 verified
    Take a look at the a2dxf.txt file in ...\share\pcb\batchhelp. You probably want to add -s and -p optional arguments.
  • ashishya
    0 ashishya over 2 years ago in reply to ashishya
    Finally in my free time i have tweaked the program and now it create all layer dxf into a single folder.
    So first create a variable with folder name such as dxdir =  "output_DXF"    \\ output_DXF is folder name
    then use createdir (dxdir) to create a directory and finally put this variable into sprintf command such as below-
     sprintf(cmd "a2dxf -$ -p -s -u MM -a 4 -f 14 -c L \"%s.cnv\" \"%s/%s_%s.dxf\" %%s" f dxdir designName filmName)
