  3. Why axlShell not same as script
  • State Suggested Answer
  • Replies 7
  • Answers 1
  • Subscribers 21
  • Views 5939
Uri Chaplin
Uri Chaplin over 2 years ago
When I run this code
; create script
Script_File=outfile("./kbg.scr" "w")
fprintf(Script_File "setwindow pcb\n")
fprintf(Script_File "zcopy shape\n")
fprintf(Script_File "trapsize 272\n")
fprintf(Script_File "setwindow form.mini\n")
fprintf(Script_File "FORM mini class_name %s\n" class)
fprintf(Script_File "FORM mini subclass_name %s\n" subclass)
fprintf(Script_File "FORM mini dynamic_shape YES\n")
fprintf(Script_File "FORM mini expand YES\n")
fprintf(Script_File "FORM mini offset %s\n" gap)
fprintf(Script_File "pick %g %g\n" xCoord(snappedPoint) yCoord(snappedPoint))
fprintf(Script_File "pop Done\n")
close(Script_File)
; run script
axlShell("replay kbg.scr")
I receive errors :
\i (00:00:47) replay kbg.scr
\i (00:00:47) setwindow pcb
\i (00:00:47) zcopy shape
\i (00:00:47) trapsize 272
\i (00:00:47) setwindow form.mini
\i (00:00:47) FORM mini class_name ETCH
\e (00:00:47) Form field label not found
\i (00:00:47) FORM mini subclass_name TOP
\i (00:00:47) FORM mini dynamic_shape YES
\i (00:00:47) FORM mini expand YES
\i (00:00:47) FORM mini offset 10
\i (00:00:47) pick 2735 1800
\t (00:00:47) last pick: 2735.00 1800.00
\e (00:00:47) Command not found: pop Done
But if I replay created script it's work without any warnings !!!
(00:00:06) trapsize 265
\i (00:00:11) script
\i (00:00:16) fillin "kbg.scr"
\i (00:00:18) replay kbg.scr
\i (00:00:18) setwindow pcb
\i (00:00:18) zcopy shape
\t (00:00:18) Select cline, cline segment, shape, rectangle or closed polygon.
(00:00:18) Loading cmds.cxt
\i (00:00:18) trapsize 272
\i (00:00:18) setwindow form.mini
\i (00:00:18) FORM mini class_name ETCH
\i (00:00:18) FORM mini subclass_name TOP
\i (00:00:19) FORM mini dynamic_shape YES
\i (00:00:19) FORM mini expand YES
\i (00:00:19) FORM mini offset 10
\i (00:00:19) setwindow pcb
\i (00:00:19) pick 2730 1805
\t (00:00:19) last pick: 2730.00 1805.00
\i (00:00:19) pop Done
\i (00:00:19) trapsize 265
What a problem ? Why is it not the same as manual script run ?
  • Hoangkhoipcb
    0 Hoangkhoipcb 9 months ago in reply to zpofrp
    Please send to me full the code.
     *Error* eval: undefined function - GenerateRenameScript
  • zpofrp
    0 zpofrp 9 months ago in reply to Hoangkhoipcb
    sent to your gmail.
