  3. Skill-Command for execute printing in the print preview...
  • State Suggested Answer
  • Replies 7
  • Answers 1
  • Subscribers 22
  • Views 5941
Skill-Command for execute printing in the print preview menu
Mabr86
Mabr86 over 2 years ago
Cadence 23.1: By executing "plot" in the command-line, the following window appears.
Is there an skill command that can be used to start printing (red arrow)?
  • mahimag
    mahimag over 2 years ago in reply to Mabr86 +2 suggested
    Hello Mabr86 , currently the "Print" button is not scriptable. As well as there is no SKILL API available. There is a Cadence Change Request(CCR) 3016239 filed for this requesting this functionality.
  • MZ20250602835
    0 MZ20250602835 over 1 year ago in reply to mahimag
    Hi Mahimag,
    may i ask you if there is a new update regarding to this issue?
    i have the same issue Allegro SPB 23.1 onward, plotwint command does not work
    for 22.1 we can use plotwint command in script to control the plot, but since 23.1 the plotwint is removed and there is currently no command to control the plot. We wwould like to define it in script via command instead of Use the File > Plot .
    Many thanks
  • Ejlersen
    0 Ejlersen 11 months ago in reply to MZ20250602835
    Hi
    This was all a change to a hotfix in 23.1, only way around this is to write code to use the new PDF generation capability.
    I've added a skeleton for you to work on that outlines how this can be done, this is not finished code to load but something pulled out from a larger piece of code. It does however show the concept.
    For the actual pdf creation commands in line 48 and 50 you need to provide the names of the films you want to be in the pdf document and also the name of the pdf file to be printet
    Hope this helps you get in the correct direction. The good thing about this that no extra install like printer drivers and gswin needs to be installed
    Ole
    https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/137/pdf_5F00_out.zip
