  3. Skill : check for shape minimum aperture of gap width
  • State Suggested Answer
  • Replies 8
  • Answers 1
  • Subscribers 21
  • Views 6704
Xiaome8
Xiaome8 over 1 year ago
Hi Bro,
I has a trouble to check for shape minimum aperture of gap width , and there is an interesting picture which can fix the issue,So can anyone help to share such kinds of skills ? thanks in advance.
  • Hoangkhoipcb
    Hoangkhoipcb over 1 year ago +1 suggested
    Hi Xiaome8! Have you tried this code yet? cmd_str = sprintf(nil "shape check; pick %.2f %.2f; fillin %L", xCoord(shape_center), yCoord(shape_center), "5.0") axlShell("cmd_str") HoangKhoi.
  • DavidJHutchins
    0 DavidJHutchins over 1 year ago in reply to Xiaome8
    All that skill code does is to run the command 'shape check'
    Below is the documentation:
    shape check
    The shape check command identifies small or narrow areas that might cause problems during artwork generation. The layout editor identifies these problems with circular figures, called shape problems, which are the same size and color as DRC markers. These circular figures display on a subclass of the MANUFACTURING class called SHAPE PROBLEMS, which is created only after the layout editor detects a shape problem.
    When checking static solid fill shapes for vector-based artwork (Gerber 4x00 and Gerber 6x00 artwork formats), the layout editor is limited to checking apertures of 4 mils or greater as specified in the Enter Smallest Aperture Available dialog box. For dynamic shapes, same the value is used as specified in the Minimum Aperture field on the Void Controls tab of the Global Dynamic Shape Parameters dialog box.
  • Xiaome8
    0 Xiaome8 over 1 year ago in reply to DavidJHutchins
    Hi David,Hoangkhoi,
    Thank for the reply, the shape check do not support muti-shape check, select the shape one by one to check is not very high efficiency, so hope to get skill to auto-check with muti-shapes ,thanks!
  • TL202608111936
    0 TL202608111936 1 month ago in reply to Xiaome8
    I don't know if you've resolved your problem yet, but I have an idea:
    - Select the shape → extract the shape's voids → convert each void into a polygon → expand the polygon → select the other voids or shape segments by using axlAddselectbyPoly→ measure them.
    Luan
