  3. Problem Running dxf2a Command via Skill Form – Invalid Program...
  • State Suggested Answer
  • Replies 10
  • Answers 2
  • Subscribers 22
  • Views 7967
Problem Running dxf2a Command via Skill Form – Invalid Program Arguments
Maxime1998
Maxime1998 over 1 year ago
Hello everyone,
I'm currently trying to create a form to simplify the import of DXF file.
I'm using the command "dxf2a" but i'm currently stuck with de command, i've read lot of documentation but i'm not sure why this command is not working.
Here is the error and the command name i'm using:
Starting DXF Import... (SPMHGE-268): dxf2a had errors, use Viewlog to review the log file.
nom de dxf2a : "C:/Cadence/SPB_17.4/tools/bin/dxf2a.exe -$ -u MM -v MM -a 4 -g C:/CAO/FGXXXXXXXYXX/INPUT/MECANIQUE/FGXXXXXXXYXXMID-1_PAGE_1 (1)_l.cnv C:/CAO/FGXXXXXXXYXX/INPUT/MECANIQUE/FGXXXXXXXYXXMID-1_PAGE_1 (1).dxf FGXXXXXXXYXX %s"
I'm using the axlRunBatchDBProgram fonction to run the dxf2a command to Cadence.
My viewlog file is looking like that:
ERROR: Invalid program arguments.
Terminating program.
In my code I'm generating the .cnv file like it should be and I don't think its the problem because I've tried to use the .cnv file generated by Cadence and it doesn't work either.
Thank you very much!
  • DavidJHutchins
    0 DavidJHutchins over 1 year ago in reply to Hoangkhoipcb
    doesn't work for me importing into a dra
    \i (00:00:05) generaledit
    \i (00:00:27) skill 'axlRunBatchDBProgram("dxf2a" sprintf(nil "dxf2a -$ -u MILS -v MM -a 2 -g MULTIPACK_l.cnv MULTIPACK.dxf %%s" ?reloadDB t ?logfile "dxf2a.log"))'
    \t (00:00:27) Starting dxf2a...
    \e (00:00:28) ERROR(SPMHGE-268): dxf2a had errors, use Viewlog to review the log file.
    (00:00:29) 2
    \i (00:00:31) setwindow text
    \i (00:00:31) close
    D:\xxx\yyy>type dxf2a.log
    Reading Layer Conversion File
    Reading DXF file...
    done.
    ERROR: Opening file D:xxx/yyy/#Taaaaad14832.dra.
    ERROR: Opening D:/xxyyy/#Taaaaad14832.dra for incremental update failed.
    D:\xxx\yyy>
  • Hoangkhoipcb
    0 Hoangkhoipcb over 1 year ago in reply to DavidJHutchins
    Hi!
    skill 'axlRunBatchDBProgram("dxf2a" sprintf(nil "dxf2a -$ -u MILS -v MM -a 2 -p MULTIPACK_l.cnv MULTIPACK.dxf %%s" ?reloadDB t ?logfile "dxf2a.log"))'
    i changed -g -> -p
    -p creates a .dra file of sympackage type.
    try it one more time.
    HoangKhoi.
  • DavidJHutchins
    All the data I am attempting to import is mapped to the 'DRAWING FORMAT' class, so the '-p' option fails
    The -f option appears to work, however nothing is saved to disk:(
    D:\D:\XXX\YYY>tail allegro.jrl
    \i (00:01:18) close
    \i (00:01:20) setwindow pcb
    \i (00:01:20) open
    \i (00:01:44) fillin "menu_cancel"
    \i (00:01:44) generaledit
    \i (00:03:25) skill '`'axlRunBatchDBProgram("dxf2a" sprintf(nil "dxf2a -$ -u MILS -v MM -a 2 -f MULTIPACK_l.cnv MULTIPACK.dxf %%s" ?reloadDB t ?logfile "dxf2a.log"))`''
    \t (00:03:25) Starting dxf2a...
       (00:03:27) t
    \i (00:03:32) exit
    \t (00:03:33)     Journal end - Wed May 14 11:16:53 2025
    D:\D:\XXX\YYY>cat dxf2a.log
    Reading DXF file...
    done.
    Layer conversion file: MULTIPACK_l.cnv
    DXF file: MULTIPACK.dxf
    BRD file: D:/D:/XXX/YYY/#Taaaaau00244.dra
    Update existing design?: NO
    Use default text?: NO
    DXF units: MILLIMETERS
    Design units: MILS
    Design precision: 2
    dxf2a complete.
    D:\D:\XXX\YYY>dir *dra
     Volume in drive D is New Volume
     Volume Serial Number is 902D-8197
     Directory of D:\D:\XXX\YYYP
    05/05/2025  09:57 AM           201,016 mp.dra
                   1 File(s)        201,016 bytes
                   0 Dir(s)  40,886,636,544 bytes free
    D:\D:\XXX\YYY>dir *log
     Directory of D:\XXX\YYY
    05/14/2025  11:16 AM               713 downrev.log
    05/14/2025  11:16 AM               323 dxf2a.log
                   2 File(s)          1,036 bytes
    Any new suggestions?
  • Hoangkhoipcb
    Hello David,
    Run the axlDesignType(t) command in the Allegro command window to check whether the -p and -f options are correct.
    Then try again.
    cmd:
    [-p | -m | -f | -s]
    Symbol file switch.
    -m creates a .dra file of symmechanical type.
    -f creates a .dra file of symformat type.
    -s creates a .dra file of symshape type.
    dxf2a -$ -u MILS -v MM -a 2 [...] MULTIPACK_l.cnv MULTIPACK.dxf  MULTIPACK.brd
    Also, change [....].
    HoangKhoi.
  • Hoangkhoipcb
    Hello David!
    Today, I encountered the same issue as you. I found a solution for it.
    Please try again.
    'DRAWING FORMAT'  -> -f -> correct.
    axlRunBatchDBProgram("dxf2a" sprintf(nil "dxf2a -$ -u MILS -v MM -a 2 -f MULTIPACK_l.cnv MULTIPACK.dxf %%s" ?warnProgram t  ?reloadDB t ?logfile "dxf2a.log"))
    HoangKhoi.
